Thread: Rod and main bearing colors
Created on: 02/03/21 01:40 PM
JoeBean
02/03/21 1:40 PM
Hey guys I'm new to the forum was hoping one of you could help me I'm rebuilding my 06 zx14 engine, I was wondering if someone knows the specs on the BLUE, BLACK ,and BROWN rod and main bearings witch ones has the most clearance witch one has the least. Thanks
RE: Rod and main bearing colors
02/03/21 8:06 PM
Welcome JB
Both rod and crank use the same color size:
BRN- Tightest
BLK - Middle
BLU - Loosest
Min .0019 and .003 is worn out. Anything above .0019" and anything below .0024" is ideal.
Tell no one... Tight is race the whole season. Loose, you'll be rolling it back up the ramp first time out. Old thought was to have a loose crank. Maybe V8's, but these little jewels like it tight for dependability.
JoeBean
02/04/21 5:54 AM
awesome thank u HUB
02/04/21 7:48 PM
JoeBean
02/09/21 10:55 AM
hey Hub you said .0019-.0024 is that for rod and main
02/09/21 12:31 PM
Correction:
Big end rod on crank journal .0019" to .0024"
Crank to case clearance .0012" to .0025"
See how they use a tighter clearance for that length of crank to keep the vibe down?
WEAR, I would begin as tight as I can get, and break the bike in a lot slower; before I hit a higher rpm.
But if you're going to drag it and have it loose, then .002" would be the loosest and avoid the vibe if the serviceable limit is almost close for both at .003" and change.
Kind of see how you'd want the tighter inserts on a used crank? So if you look at both insert settings, yeah, .002" for both and you're good to go.
JoeBean
02/10/21 5:16 AM
thanks man
